What is an InsertLine failure?
Posted: Thu Dec 06, 2018 8:48 am
When creating certain polyhedra which is either extremely complex or contains parts which can cause great round-off errors (such as very small angles or angles near 180° degrees, Stella glitches out with an Internal Error that InsertLine has failed.
The full quote goes:
Here are some ways to easily get an InsertLine failure:
An InsertLine failure can be particularly problematic. The only way to deal with it is to force close the program.
This effectively hangs the program and it ceases to respond - as if it has gone into an infinite loop upon the failure of "InsertLine."InsertLine failed. Maybe model not accurate enough?
- Extremely complex models.
- Models which involve very small angles or angles very near π. I believe Stella uses numerical approximation, and trigonometric approximation becomes problematic especially near, but not at these "critical" angles. I believe π/2 is another critical angle.
- High prisms and antiprisms (these have bases of many-sided polygons). In fact, InsertLine fails for antiprisms whose polygons have 100 or more sides when you view the faces.
