Coincident edges
Coincident edges
Does Great Stella coalesce vertices and edges that coincide? I have some OFF models for which it says there are more than two faces meeting at some edges. That's not true in these models' abstract structure.
Re: Coincident edges
No Stella keeps them separate, so edges with 4 faces would count as two edges each with two faces.
But what you're seeing is only a warning, not an error. Just click OK and it should be fine.
Yes, I've been clicking through and it started to get old. I would modify the models to avoid the message but I can't figure out what's triggering it. I've checked carefully and each edge that exists appears exactly twice in the definitions of the faces. Thanks for ruling out one possibility.
