For some reason after 25 models built successfully the printouts don't have the ID numbers, especially now with 1000 pieces, any help appreciated.
Uninstall - reinstall?
ID tabs
Uninstall/reinstall is almost never the best answer.
The IDs to identify matching tabs is an option when printing nets. Maybe the option got unticked somehow. When printing nets, you'll find "Edge connection IDs" in the top right corner of the dialog box that appears. Make sure that option is ticked.
Let me know if that fixes it.
Can you send me a screenshot of that options window? There may be something else in there that's relevant. And a screenshot of the new preview.
By the way, the IDs will appear in the print preview, so you don't actually have to do a print out to check if it's working, but you probably know this already.
Does the problem occur for all polyhedra now? Or maybe there's something unusual about the model you're trying to print.
Did something change on your system around the time it stopped working? It still works fine for me.
- Peter Kane
Just a stab in the dark - maybe its the printer driver ? If you have a different printer, you could try printing it on that. Failing that, perhaps you could try something like the MS XPS Document Writer, if that is available on your system. If it is, then when you print the net, click on the printer properties button , choose the appropriate driver and tick the option that says to automatically open the XPS viewer. I just tried this with a dodecahedron and I could see the ID numbers on the tabs, so that proves that (in this case), Stella was doing the right thing.
- Peter Kane
Hmmm
Looks like its that sort of day.
I cant see all of my response, so here it is in chunks:
