A few pics
Robin Adair
Re: A few pics
Post by Robin Adair » Thu Nov 07, 2019 6:56 pm
Wow! Those are stunning. (Would you be able to post the files?).
Since I’ve just begun making compounds, I haven’t gotten into the fine points of alignment. What I did was to bring the three polyhedrons into a memory slot for each one. My first attempt created one inside of and hiding the other. I realized that I needed to make each a different size, to expose parts of it. I gave each a different color before combining them. I used the mouse to align them, then combined them. When I began to build the model, I realized that I was lucky to get the individual parts aligned as well as they were.
How can I rotate and move the individual parts with better precision than simply spinning them with the mouse? Or is there a better way to do this? I was thinking of taking, say two tetrahedrons, point to point, and “covering” the connection with another polyhedron, perhaps one with holes, showing the connection (just as an example). I haven’t played with the program enough to discover how such things are done
marcelteun
Re: A few pics
Post by marcelteun » Fri Nov 08, 2019 11:55 am
Hi Robin,
I am sure you can combine these with Stella by just adding the compounds as described below, but I let Robert answer that, since I am not familiar with Stella.
I uploaded a zip file (temporarily) on my own site with the two models shown:
https://tunnissen.eu/tmp/14_cubes.zip
Re: A few pics
Post by robertw » Sat Nov 09, 2019 5:56 am
You want to combine compounds that already have the same symmetry group, then they should be aligned.
Before putting them into a memory slot, make sure they're all the same scale by setting "Scale->Base Polyhedron Radius" to the same value for each.
Robin Adair
Re: A few pics
Post by Robin Adair » Sat Nov 09, 2019 5:00 pm
I have to admit a bit of ignorance. What is meant by the term “symmetry group”? Or, the mu variable? I took high school geometry in 1971, but haven’t used it much since. I didn’t get into trigonometry much, and have forgotten it anyhow by now. Is there a book I could use to bring me up to snuff in this field?
Re: A few pics
Post by robertw » Sun Nov 10, 2019 10:56 am
Hi Robin,
I don't know where you saw the "mu" variable.
You can find "Symmetry Group" in the glossary here: https://www.software3d.com/Glossary.php#symgroup
It's just the collection of symmetries that an object has, eg reflection in a plane, or rotation around an axis.
All I meant was to start with models of the same symmetry. You can see the symmetry group of a model in the toolbar
Here we see that the current model has icosahedral symmetry, including reflection.
Previously I suggested combining the compounds of 6 and 8 cubes. These compounds both have octahedral symmetry, so they should combine well.
marcelteun
Re: A few pics
Post by marcelteun » Wed Nov 13, 2019 10:11 am
That he must have picked up from me. For the compounds with rotational freedom I use the angle mu. I think I use the same Greek letter as in "Symmetry Orbits". For one of the compounds I used 6 | S4xI / C4xI | mu.
Marcelteun
Re: A few pics
Post by Peter Kane » Sat Dec 21, 2019 11:34 am
Back near the start of this long-running thread, Rob Adair lamented the fact that the pictures in Magnus Wenninger's book are in black and white. I'd have thought that there are enough posted photos in this newsgroup to cover many of them. Wouldn't it be nice to assemble a pdf of these images (subject to receiving permission, of course) ? I suppose a website would be the obvious alternative, but I much prefer the printed page.
marcelteun
Re: A few pics
Post by marcelteun » Wed Jan 08, 2020 12:16 pm
There are people here who built all of them,.. (Not me, and I have no interest in that either)
Robin Adair
Re: A few pics
Post by Robin Adair » Thu Feb 20, 2020 7:10 pm
This is a model of Bruckner 23,7 (5,7). I thought I would try tans, browns, and beige. Did this one about two months ago.
Robin Adair
Re: A few pics
Post by Robin Adair » Thu Feb 20, 2020 7:16 pm
Here’s a compound of Great Dodecahedron and Great Dodecahemidodecahedron. Basically, I wanted the star placed in what would have been a pentagon, for strength. To do this, I scaled it to where the points of the star met the points of the pentagon.
Re: A few pics
Post by robertw » Fri Feb 21, 2020 7:05 am
Very nice. Those Bruckner models are mostly painful to make!
Robin Adair
Re: A few pics
Post by Robin Adair » Wed Jun 03, 2020 3:57 pm
Here’s a couple of recent projects.
The first is a compound of 5 Tetrahedrons and a Small Stellated Dodecahedron.
The second is a compound of 3 Cubes and 3 Tetrahedrons.
Re: A few pics
Post by Ulrich » Thu Jun 04, 2020 8:46 am
The second compound is really cool.
You had to cut and glue some very small facelets.
marcelteun
Re: A few pics
Post by marcelteun » Mon Aug 17, 2020 8:46 am
Beautiful work! I like compounds in general (currently I am building the rigid compound of 15 cubes). I really like the compound of the Small Stellated Dodecahedron and the 5 Tetrahedra. :D
