Wall Thickness
hamp856
Wall Thickness
Post by hamp856 »
I am making plutonic objects out of wood. I have had resonalble success. I want to take the objects I make, put them in a wood lathe and turn them into spheres. Does anyone know how to calculate the thickness of the wood before it is turned to achieve a final wall thickness of 1/2"
Hamp
Post by guy »
Well, the wood will be thinnest in the corners and thickest at the centre of each piece. Assuming you want at least 1/2" everywhere, you need to:
Take the difference between the inradius (radius of the sphere tangent to the faces at their centres) and the out- or exradius (of the sphere tanget to the vertices). That tells you how much fatter each piece is in the middle.
As a rough approximation, add 1/2" to get the starting thickness. You could calculate more accurately but it would depend on some complicated angles of each Platonic, so personally I'd just round the number off to a handy thickness - if it's a tetrahedron I'd round down.
HTH
hamp856
Post by hamp856 »
Hey, Thanks a bunch for the info. I see in Stella 4-D under the Scale Tab an item for "inradius" but I don't see the "out Radius" There are several tabs underscale. Which would you use ?
This week end I was able to build a "Rhombicosidodecahedron". I had good success for a first shot. I made it out of MDF plywood since it was prototype. It is about 13" in dia. I'll post a picture as soon as I can get my hands on a digital camera.
thanks for your help.
Circumradius (or out-radius) is simply referred to as "Radius". Technically speaking, a polyhedron may not have a circumradius, which would have to go through all points, so I just use the more generic term radius.
hamp856
Post by hamp856 »
Thanks, I see the objects you build. What material do you use. How do you cut the angles necessary?
I am experimenting with a product called "Sign Foam" which is "high density polyunrethane. It is perfect for these objects.
Hamp
I presume that question's for Guy? I only make models from paper. Just wanted to answer the part of the question I could :)
hamp856
Post by hamp856 »
I made an "Archimedan Rhombicodidodechedron" how do I post a picture of it?[/img]
See this thread, about posting images: http://software3d.com/Forums/viewtopic.php?t=23
Post by guy »
robertw wrote:I presume that question's for Guy? I only make models from paper. Just wanted to answer the part of the question I could :)
No, I don't post images of real models (except the odd icosahedron in a museum that I think may have been made by H.T. Flather of Coxeter, Du Val, Flather and Petrie fame).
And yes, circumradius is the usual term. I knew that. :(
hamp856
archimedan rhombicosidodecahedron
Post by hamp856 »
If am building a "archimedan rhombicosidodecahedron" how do I calculate the # of vertices?
Hamp
Stella shows number of vertices in the Info window.
Otherwise, you could note that each vertex touches exactly one pentagon. There are 12 pentagons, and so 5 x 12 = 60 vertices.
