The dart shaped facets are divided down the middle as you are using two colours for each.
Presumably you are double-tabbing, so the dart shaped facets will effectively be hinged down their middle.
How does this affect the overall rigidity of the model? Did you need to use any internal bracing?
Robert - your new model of Ten Tetrahedra
Looks great! What answer did you come up with for internal bracing?
You can see what I did here: http://www.software3d.com/10Tet.php
I didn't use any.
I try to avoid using internal bracing. It is essential for 5 Cubes, but all the others have proven to be rigid.
Have to admit that 10 Tetrahedra is a big disappointment. Lots of lovely colour, but the shape is a bit too much boring dodecahedral.
It's not a proper compound by my rules as it's 5 left hand oriented and 5 right hand oriented tetrahedra.
Nevertheless, I've made it and it's sat filling space in the display cabinet.
