Sorry, my Google-fu has drawn a blank on this...
Can Stella net a 'ball' shape consisting of a short, pentagonal prism capped at both ends by a truncated pentagonal pyramid ?
So, it has five parallelogram or square faces, ten trapezoidal faces and two pentagonal ends ??
I'd also like to export it as OBJ, so we're probably talking 'Great Stella'...
Thank you.
A 17-faced whatsit...
Re: A 17-faced whatsit...
Yes it can, here's how (you need Great Stella for this)
- Start with a pentagonal prism:
- If you want to change the pyramid height before starting, use "Scale->Stretch (Non-Uniform Scale)"
- Select a pentagonal face
- Use "Poly->Augment Polyhedron" (keyboard shortcut: a)
- In the dialog that appears, select these options: Augment using...Prism (everything else can stay as default). You'll see this preview of the augmentation:
- Use Ctrl+Right-drag to scale the top of the prism as required:
- Use Ctrl+Left-drag if you want to change the height of the augmentation:
- When happy, hit Enter to accept the preview as your new model
- Now you can see nets, eg here it is with the 3D unfolding nets:
Thank you, thank you.
I have ordered a 'Great Stella'.
