Work in progress
Work in progress
This is the sixth stellation of my model of the great snub dodecicosidodecahedron, which is No. 115 in Magnus Wenninger‘s book „polyhedron models“. Nine further stellations are to come. The edge length will be 30 cm. There are 15 colours, 6 for the snub triangles, 5 for the icosahedral triangles and 4 for the pentagrams.
Re: Work in progress
Looks great! Must take a long time. Looking forward to the finished model.
Thanks! I‘ll keep you current
Awe-inspiring! What will the radius be? I've seen several of your models in the past, but previously, I've only considered the holes in the faces to be decorative. Having spent a few minutes studying the current image, I see that the holes also permit a better appreciation of the structure of the polyhedron. They allow you to observe the intersecting faces in a similar way that the models with natural holes (like W 63) do. This might be an alternative to using transparent sheets. I guess I'd need a laser-cutting-thingy though (are you listening, Santa?).
Thanks for sharing.
The diameter will be 396 mm. You‘re right, the pattern is based on the stellation diagram.
A laser cutting machine works well and can accelerate the process a lot. I could gather some experience in the past. The results are very precise but a little „sterile“. And although it can be rather painful, I love cutting the paper by hand with my scissors and knives.
Here is stellation no. 10:
This is stellation no. 14.
I think I'll finish it next year.
This is the finished model:
Well done, looks great!
Thanks!
W116 is in the works
I‘m very glad that it received the prize as best 3D artwork at this year‘s Bridges Conference in Linz.
Well done!
marcelteun
Post by marcelteun »
Ulrich wrote: Sun Jul 21, 2019 7:24 am I‘m very glad that it received the prize as best 3D artwork at this year‘s Bridges Conference in Linz.
That is Cool! Congratulations, I am sure you deserved that. What a work!! Good luck with the next one!
marcelteun wrote: Mon Sep 23, 2019 11:25 am That is Cool! Congratulations, I am sure you deserved that. What a work!! Good luck with the next one!
Thanks! The work at the next one is languishing a little bit, but I still hope to finish it this year.
After four years I finally finished W116:
I started W117 and hope that it will take less time to get it done.
Well done, amazing job! Was this the one you said you hoped to finish in 2019?!
