stav242
Post
by stav242 »
im tying to export to obj, with each surface defined in the obj as a component.
i get what i need when i export with `spheres and cylinders` - but i dont want them in my exported object.
anyone know how i can export the shape, with the faces defined ?
.. see example pics..
Post
by robertw »
It exports a single object (lines starting with "o" in the OBJ file), but groups sets of faces together based no colour (lines starting with "g").
So anything you want separate should be a different colour.
I don't know why exporting the edges and vertices would make a difference.
If you're only intersected in convex models, you may also want to choose "Don't triangulate faces" when you export.
stav242
Post
by stav242 »
ok, i change to `colour per face` and oddly.. that seems to have resolved my issue. each `face` in now individually selectable in the mesh.
thank you.
