New to Stella - is there a way to combine OFF files?
Exactly what it says on the tin
I created two polyhedra that I think look very nice, and would like to create a compound of them. Is there any way to do so in Stella that I am unable to find, or some other tool I can use?
Re: New to Stella - is there a way to combine OFF files?
You can use the "Edit->Put Model in Memory" submenu to pick a slot to save it to (or keyboard shortcut "m"). Then load other model. Then combine them with "Edit->Add/Blend from Memory".
If they have the same symmetry, then they should align well. If not, your milage may vary.
